dimons писав:Какая скорость потока возможна при использовании?
Вот тарифная сетка компании ДатаСат(ДатаГрупп)
http://www.internetboom.ua/ru/tariffs/
Это параметры модема
Table: Hughes DW 7000 tech specs Technical Specifications
Physical Interfaces:
Ethernet LAN: One 10/100BaseT Ethernet LAN RJ45 ports
Satellite & Antenna Specifications:
Outbound transmission format: DVB-S
Information Rate (Receive): Up to 90 Mbps (DVB-S2)
Information Rate (Transmit): Up to 1.6 Mbps
Symbol Rate (Receive): 1, 1.25, 2.5, 5-30 Msps (in 1 Msps steps)
Symbol Rate (Transmit): 128, 256, 512, 1024 Ksps
Encoding (Receive): DVB-S Convolutional with concatenated Reed Solomon
Encoding (Transmit): Turbocode FEC 1/2, 2/3, and 4/5
Frequency Range: Ku-, C-, Extended C-, and Ka-band
Modulation (Receive): QPSK, 8PSK (DVB-S2)
Modulation (Transmit): OQPSK
Bit Error Rate (Receive): 10 exp-10 or better
Bit Error Rate (Transmit): 10 exp-7 or better
Antenna: 74 cm, 89 cm, 98 cm, 120 cm, 180 cm
Radio: 1 and 2 watt Ku-band, 2 watt C-band, 1, 2, and 3 1/2 watt Ka-band
Power Supply:
Universal Power Supply: 90 - 264 VAC; 47 - 63 Hz
DC power supply (optional): 12 to 24 VDC
Operating Temperatures:
Indoor equipment: +0ºC - +40ºC
Outdoor equipment: -30ºC - +55ºC
Mechanical & Environmental
Weight: 2.18Kg (4.8 lbs)
Dimensions (IDU): 29.21cm W x 4.7cm H x 27.94cm D
(11.5"W x 1.8 "H x 11 "D)
